Missing pallate
In my labview program micromanager.net is missing. How to add it ? ( Refer fig umanager.PNG)
(2,889 Views)
What is "micromanager.net"?
I assume that you want to interface to that micromanager via .NET. The first question is: Does micromanager have an exported visual interface?
If yes, you can add it INTO a .NET container which is shown in your screenshot.
If no, you have to interface programmatically which means you require a constructor node on the block diagram...
Norbert
Expert: Geometry
(2,857 Views)
I have installed some panels. I couldn't add what is required for me. (Refer figure tool1.PNG and tool2.PNG)
But I need my control palette as shown in figure( Refer Micromanager.PNG)
Kindly help
(2,843 Views)
You can try using tools-->Import --> .NET Controls to Palette..
Then you may need to use Tools--> Advanced --> Edit Palette set to customize the palette
(2,833 Views)
I tried the option
Tools>Import>.NET controls to palette
When I click browse I cannot find an option 'micromanager.net.dll'.
Do I have to install anything for that?
(2,819 Views)
This does not seem to be part of LabVIEW.  A Web search leads to something called MicroManager.org.  Check it out.
(2,814 Views)
