Missing files
A project that I am working on has following 4 files missing;
<userlib>:\String_VIs\Rev 1.00\SearchStringForMultiplePatterns.vi
<vilib>:\DAQ\ZADVD.LLB\Digital Single Write.vi
<userlib>:\String_VIs\Rev 1.00\StripChars.vi
<vilib>:\DAQ\ZADVD.LLB\Digital Group Config.vi
Which LabVIEW driver or package I need to install?
Is there an easier way to find out the answer to the above question using LabVIEW (and not bothering the good, busy guys at this forum)?
Thanks guys!
(2,795 Views)
You need to install Traditional DAQ, and then you should have access to these VIs, if you installed the correct version of Traditional DAQ for your system and LabVIEW.
If you are using LabVIEW 6 and you want to run this VI you will need to install an older version of DAQ.  To see what versions of Traditional DAQ are available for your version of LabVIEW please look
here. You can find and download that driver from here.
If this does not help you out, can you please post back which version of LabVIEW and Traditional DAQ you have installed?
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(2,786 Views)
