Missing buttons
So this may be a silly LabNOOB question I have, but...
Every time I right click and select "create a control/indicator" I get something that looks like the one on the left, big and boxy.
But every single control/indicator I see on these labview forums look like the 2 on the right.
I have some .vis that people have helped me troubleshoot and they have put those controls/indicators in, so I can go into that .vi and copy/paste them into other programs but that is a pain in the tuchas.
Where are these buttons?  I cannot find them.
Also, can I make it so that right clicking and selecting "create a control/indicator" will default to the style on the right instead of on the left?
(3,151 Views)
I am running labview 8.5 by the way, in case that matters.
(3,150 Views)
Accepted by topic author LarsUlrich
Right-click the terminal and unselect "show as icon".
There is also a configuration option that determines what kind of icons you get when creating controls or indicators.
(3,147 Views)
The configuration altenbach mentioned can be found by navigating to "Tools > Options..." - select Block Diagram from the category and then uncheck the "Place front panel terminals as icons.  This will change the default, if you prefer the smaller form factor. Smiley Happy
Peter D
(3,116 Views)
