Missing assignment to tunnel - LabVIEW - NI Discussion Forums
I'm programming a VI that makes a calibration file from an RF-generator.
It works over the LAN and goes to a GPIB interface, no problems there.
But when communicating with the power meter I can't close the loop.
A copy of my VI is attached thanks in advance.
The other loops and devices communicate perfectly can't see what my mistake is
I've been debugging for three days.
(2,757 Views)
Hi
You have to tunnels there which are above each other. Just click the tunnel and move it down with the down-arrow key. Then you'll see that there are two tunnels.
Thomas
Message Edited by becktho on 05-02-2005 12:56 PM
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,753 Views)
Thank you very much
(2,730 Views)
