Missing Window Run-Time Position in LabView 7.1
I am using LabView 7.1 and I found this article:
http://digital.ni.com/public.nsf/allkb/5FEB0ED42C700C9B86256EEB00527ECE
It shows how you can programmatically setup multiple panel windows to appear on screen when called by the main VI, with predefined size, position as well as window priority.
I have LabView 7.1 and I do not have this "Window Run-Time Position" option discussed in the above article, under my File>>VI Properties. I have the "Window Appearance" and "Window Size" options, but not the "Window Run-Time Position".
Basically I have 4 automated custom popup window reminders for the end users. I setup the subVI property of each window in the block diagram to open the panel in a specific predefined location within the computer monitor. I don't want them to completely overlap as the user only sees one window and the other 3 are hiding behind it. However I also want to set each window priority. When the subVI is called if it is window 2 for example, have it always appear behind window 1 but always on top of windows 3 & 4, in other words have priotity 2. No matter when they are called.
Is there something wrong with my LabView 7.1 installation? Is this some kind of add-in function I need to install? Does anyone know why I am missing this "Window Run-Time Position" option from my File>>VI Properties??
Any help would be appreciated it.
(2,565 Views)
No, there is nothing wrong with your LV 7.1 installation.
Sadly, the linked KB does not point out that "Window Run-Time Position" is a new feature introduced by LV 8.0.
Refer to the LV 8.0 Upgrade Notes for this information. You find it on page 83.
Norbert
PS: If you consider upgrading, you should go to a more up-to-date version of LV. Please note that NI does not support any combination of OS and LV. You can see supported combinations on the LV product lifecycle webpage.
Norbert
Expert: Geometry
(2,554 Views)
Thank you for the disappointing news Smiley Sad
(2,545 Views)
