Missing Teststand Vi's with new Labview/Teststand install
All,
This may be a silly question, but I installed Labview and Teststand fresh on a new machine. When I start Labview, all of my Teststand Vi's (Labview VI's that reference Teststand) from the block diagrams are question marks...and of course from select menu too. Does anyone remember how to correct this? I only installed once and never had this come up.  Thoughts?
(3,843 Views)
Here is a photo of what I am talking about.
(3,827 Views)
Accepted by topic author SimpleJack
Hi SimpleJack,
What was the order of your installation; LabVIEW first or TestStand First? If you installed TestStand first then the picture that you showed is a possibility.
Perry S.
(3,812 Views)
Make sure that the version of TestStand you just installed is the Active Version, I know that sounds silly because you just installed it but I have had issues where it still wasn't 'active' after a fresh install.
Use the 'TestStand Version Selector' and make sure you activate the version you just installed.
PH
(3,802 Views)
It ended up being the order of installation. Corrected! Thanks.
I installed Teststand first....doh.
(3,793 Views)
