03-28-2007 10:56 AM
03-30-2007 12:50 PM
02-29-2008 09:01 AM
I'm getting the same error when I try to build an application for a Pocket PC 2003 target device. The calculator example builds and runs on the PDA. Is the error caused by missing symbols in the lib file provided for the library call? If so, does that mean I'm using the wrong SDK for the target?
05-29-2010 05:38 AM
06-01-2010 10:55 AM
Hi Vincent,
It's hard to say, What is the problem you are having? Lets try to get it solved.
06-01-2010 11:26 AM
Vincent,
I was able to use the executable file created when I included the library file from the PocketPC 2003 SDK on my targets. In my case the library file I needed was the iphlpapi.lib file.
I notice that both the MT606 and the EP9315 SDK are newer than the PocketPC 2003 SDK and that the ARMV4 library folders contain both an iphlpapi.lib and an iphlpapi.exp file while the PocketPC 2003 ARMV4 library folder has only the iphlpapi.lib file. Does anyone know if that is significant?
Dave
06-01-2010 11:28 AM
Please see also this thread and the attachment:
http://forums.ni.com/ni/board/message?board.id=170&message.id=501848#M501848
06-04-2010 02:54 PM
Hi Vicent,
Thanks for your patience. We are currently working on this issue internally. We will post the solution here when it becomes available.
Thanks! |
04-21-2011 01:50 PM
hello sir..i am manoj..i wanted to know from wher i can download the arm.vi subvi for labview to place it in the blockdiagram....
its very urgent sir..i need ur reply very soon..plz...and also lket me know how to use it...thanking u sir...urs manoj
04-25-2011 06:32 AM
Hi Manoj,
Could you please explain what you are looking for? This thread has to do with call a C dll in different Arm architechures.
