Missing SubVI's
I am running LabView version 8.6 on a windows xp virtual box. I was assigned this project and was given LabVIEW code to get started. However, when I open it and try to run it errors show up.
Block Diagram Errors
Poly VI 'Read.vi': SubVI is missing
Poly VI 'DAQmx Read.vi': SubVI is missing
SubVI 'Configure Input Signal.vi': SubVI is missing
SubVI 'Configure Reference.vi': SubVI is missing
SubVI 'Configure Sensitivity and Reserve.vi': SubVI is missing
SubVI 'Configure Filter.vi': SubVI is missing
SubVI 'Configure Channel Display.vi': SubVI is missing
This project uses a GPIB-USB-HS. I believe the driver is installed for this machine, however maybe I am missing something? Any help would be greatly appreciated.
Thank you,
Natalie
(5,205 Views)
You need the DAQmx drivers
/Y
Qestit Systems
Certified-LabVIEW-Developer
(5,200 Views)
Accepted by topic author nsmit106
Check this chart and make sure you have the correct version of DAQmx installed.
I'm not sure what the "Configure ...." VIs are.  They may be part of the drivers for the particular GPIB instrument.  Check the manufacturer's website for those drivers.
Edit:  Go to the Help menu in LabVIEW and click Find Instrument Drivers.  Use this to first search for the instrument drivers.  Very easy to install from here if they are NI certified and hosted.  If not found here, then search the manufacturer's website.
aputman
(5,193 Views)
Thank you for your help! The chart is useful and I will look for the drivers specific to the GPIB.
(5,175 Views)
