Missing NetClusterArrayToString.vi
I'm trying to get started using an NI-8473 CAN Module.  Example code I've downloaded can't find a vi called NetClusterArrayToString.vi which I'm assuming is supposed to be part of the NI-CAN library?
I'm wondering if anyone has seen this problem before or can at least let me know if that vi is part of the NI-CAN library and maybe I just had an issue with my install?
Richard
(3,214 Views)
Hi Richard,
You are correct, that VI is a part of the NI-CAN library. I was able to find it at C:\Program Files (x86)\National Instruments\LabVIEW 2015\vi.lib\nican in the Utilities.llb. I would double check this location, double check where the example is looking for the VI at,  and consider reinstalling your NI-CAN driver.
Best of luck!
Rita Prather
Software Product Manager
rita.prather@ni.com
(3,175 Views)
