Missing Motion VIs in LabVIEW
I am running LabVIEW 2012 with NI Motion 15.0 on Winidows 7. I have installed also the NI-DAQmx 15.5.1 but the motion VIs are missing in the functions palette from LabVIEW.
I have checked the compability of LabVIEW 2012 and NI Motion 15.0 and it should be okay.
I am using LabVIEW for the first time and I have no idea why the VIs are missing. Does someone have a solution for my problem?
Thank you!
(3,251 Views)
I'm not sure LabVIEW 2012 is compatible with NI Motion 2015.  Generally older versions of LabVIEW cannot use VIs from subsequent releases.
(3,225 Views)
What LabVIEW 2012 are you using?
32bit or 64bit. Cause Motion isn's working with LabVIEW 64bit
Martin Ammon
Trainee Application Engineer
NI Germany
(3,203 Views)
