Missing Files in Modulation Toolkit
Hello everyone,
I am trying to make a Source Distribution of a LV Project, including dependencies from Modulation and Spectral Measurements Toolkit. The directory
.../LabVIEW 2012\vi.lib\addons\Modulation contains a niAMT.lvlib. The screenshot in the attachment1 shows the library content.
Obviously there are some files missing. Since the library is not consistent, the build tool does not allow to make a Source Distribution.
I followed the RF Toolkits Installation Order (digital.ni.com/public.nsf/allkb/B256E03772F6869686256FF50065CCA2) but the result is the same.
Attachment2 shows the screenshot of the Modulation directory.
My software :
LabVIEW 2012 SP1,
Modulation Toolkit 4.3.3,
Spectral Measurements Toolkit 2.6.3,
NI-RFSA driver 2.5.5.
What can be the problem and where to get these missing files?
(3,918 Views)
the VIs missing for me too.
Have you found them by now?
Greetings!
(3,787 Views)
Hi phil-real.
It seems that the libraries are not correctly installed only under Win 7 64-bit. With Win 7 32-bit it works well.
Let's hope the problem will soon be adressed.
Cheers.
(3,783 Views)
Okay good to know.
You have now copied it from another system?
(3,780 Views)
