08-06-2024 07:55 AM
Hello all,
I am new to Labview, and I am trying to look into DAQmx examples to help set up connection to a device.
Unfortunately, I cannot find the examples in the example finder as described in some of the learning modules: the folders are entirely absent.
Attached is a screenshot of the Hardware I/O folder in the example finder, as it is for me.
I have dug through the Labview folders to see if the examples may be found there, and while I have found example DAQmx projects, I seem to be unable to open them
I am trying to find the continuous voltage measurement example.
I have found this thread with a similar problem, but I find the solution doesn't apply to my situation: Solved: Re: Missing DAQmx - NI Community
The versions mentioned are out of date, the link in the solution is dead, and my install is controlled by my organization.
If anyone can point me to where i can find data acquisition examples for these devices, I'll be most grateful
Version installed: 21.0.1f2
Device drivers installed: 2021 v1 EN
08-06-2024 03:09 PM
First check in NI-MAX under the Software section to confirm you have DAQmx installed. If so, you may have installed it without the examples. They should install by default, but you can re-install DAQmx and select to add them if you need.
Installing LabVIEW NI-DAQmx Examples in Windows - NI
You can get DAQmx installer here: NI-DAQ™mx Download - NI
If you can't install without IT permission, you will have to pass this info along to them. Make sure they select the correct version to download. Everything from 2024-Q3 to the ancient version 9.0 is available.
08-08-2024 03:31 AM
Thank you for your response.
Looking in NI-MAX, I see that DAQmx has been installed.
Unfortunately, I cannot adjust the install to install the examples. I will see if I can take it up with my IT department.
