Missed samples with acquire sound block
I'm trying get the size of the array data from the acquire sound block. I have set it up at 44100 Hz sample rate and 1 second of duration.
But the size I get is 33075 samples, instead of 44100. I don't know where are the 1025 missed samples, maybe this samples are used to carry the timestamp and dt info.
Can anyone help me with this?
Thanks!
(2,858 Views)
Wow, good discovery.  Just tested your code and can reproduce the same issue.
Very curious.
http://www.medicollector.com
(2,794 Views)
Try the attached code instead.  It sets up up a "continuous" recording, but then terminates itself after the required amount of data has been received.  That works well.
But what is interesting is that this VI also only returns 75% of the requested data if you set it up in "finite" mode.  Just like your previous VI.
Very curious.  Looks like a bug to me.  You should report this to NI.
(2,793 Views)
hello josborne,
I reported this issue to NI on Monday but I have not response by now.
Tomorrow I'm going to try your code, and see how the continuous and finite recording mode works.
Thank you!
(2,790 Views)
I do have the same sampling issue. Is this resolved?
(2,722 Views)
Check the release notes for the latest version of LabVIEW.  I seem to recall that this was fixed in one of the recent releases.  Maybe one of the service packs.
(2,718 Views)
