Misplaced Keyed Array.ctl in AMC installer
The installation from amc_2104_installer.zip calls Keyed Array.ctl from <user.lib>\Utility\Keyed Array but the installer places a control that seems to work in <user.lib>\Tools\Keyed Array\Tools_KeyedArray KeyedArray.ctl. This path must be discovered manually as examples are used.
Is this expected and can the relocated controls and VIs be considered correct?
David McMillan
(4,069 Views)
Hi David,
I would imagine that this control would work the same and shouldn't be a problem.  I would suggest posting in the thread for the AMC library (http://forums.ni.com/ni/board/message?board.id=Components&thread.id=91) where the developers of the library may better be able to answer the question.
(4,055 Views)
After looking through Help and every drop down I could find, I cannot seem to locate a way to post a message to the AMC Library board. It was my desire to post there originally, but I couldn't get a "Post New Message" with that board active.
The library seems to function properly once the Keyed Array.ctl link is replaced.
Thanks for you reply and maybe someday I'll get the forums figured out!
David McMillan
(4,044 Views)
David,
Can you get to the link Kyle posted earlier?  If so you should just hit the Reply button on any of the messages on the left hand side above people's names which should allow you to post to the AMC thread.
Sincerely,
Jason Daming
http://www.ni.com/support
(4,036 Views)
