Mismatch between Static & Dynamic control refnum
I'd like to know if there could be special scenarios where the refnum for a given control using a static reference might be different from its refnum obtained dynamically (i.e. from the event structure, or Controls[] VI property node.
It happened to me, we have a Boolean button defined from a custom .ctl typedef. We have many of them in the VI. Most of them doesn't have the issue, the static/dynamic refnums match, but few of them has the problem, any clue why?
Cheers,
Jimmy
(2,840 Views)
I tested with LV2014 and it looks like the issue has been fixed.
Attached a 2011 VI that will behave differently in LV2011 and LV2014.
(2,813 Views)
