Minus data
Need help:
For example:
This is my data:
10(user input)
i want all the between value from 0-10 to be listed.
How to do that?
Message 1 of 9
(4,671 Views)
I require some more information. Where (Which format/indicator) do you want to list the data?
Try this vi
Into the pursuit...
Maverick
Message 2 of 9
(4,668 Views)
Can i get it in Labview 8.0 ..plz thk u.
Message 3 of 9
(4,660 Views)
Try This..
Message 4 of 9
(4,654 Views)
If I understood your question incorrectly please give me more info.
Into the pursuit...
Maverick
Message 5 of 9
(4,653 Views)
jeyanthi wrote:
10(user input)
You want as integers or float?
You can use Random Number Generator & multiply it ny 10.
- Partha ( CLD until Oct 2027 🙂 )
Message 6 of 9
(4,630 Views)
jeyanthi wrote:
This is my data:10(user input)
Sorry i have no LabVIEW in my system right now else ill give u a screenshot. Try this.
Use "Get user from input" function to get the user input (10). Connect the input to the 'N' terminal of a FOR loop and inside the loop, connect a build array to the 'i' terminal of the FOR loop and create an indicator after the build array output. This will give you what you want. Post back if problem solved.
Message 7 of 9
(4,625 Views)
Please see the pictures attached to this post...
Into the pursuit...
Maverick
Message 8 of 9
(4,621 Views)
I'm curious.  How does the subject line "Minus Data" relate to the question that was asked?
Message 9 of 9
(4,580 Views)
