Minimize LabVIEW Application (EXE) to Icon on Task Bar?
Hey,
I want to run a LabVIEW Application (EXE File, LabVIEW 8.2) everytimes in backgrund. Frontpanel should visible only on activation. After minimize application only a small icon (not the large Task Button!) should visible on right corner of Task Bar. Is that possible by a LabVIEW Application?
Thank's in advance.
Kind regards
C. Dietz
Christian
Test Engineering
digades GmbH
www.digades.com
(5,394 Views)
Try File -> VI Properties -> Window Run-Time Position -> Position: Minimized.
------- LabVIEW 2009, So Easy, Even a Therapist Can Do It -------
(5,388 Views)
C. Dietz, www.digades.com wrote:
Hey,
Thank's in advance.
Kind regards
C. Dietz
The right corner of the Task Bar is called System Tray.
This can be done with G Toolbox -> Systray Icon VIs:
George Zou
(5,375 Views)
Or with this ActiveX object.
P.S. George, it's actually called the "notification area", at least officially. Smiley Very Happy
___________________
Try to take over the world!
(5,368 Views)
However, System Tray is a much more popular name for it.
Message Edited by zou on 11-06-2007 09:24 AM
George Zou
(5,365 Views)
