Microsoft sharepoint
I am interested in communicating with MS Sharepoint Portal via Labview. Essentially, I want to dump data from Labview to Sharepoint Column. Can anyone help me.
HUz
Message 1 of 12
(10,091 Views)
HUz,
I don't know much about Microsoft's SharePoint.  But I just took a quick scan through the Wikipedia article and picked out the following line:
"The SharePoint user interface is a web interface accessed through a browser."
This would make me think that you could use web services to communicate between the two, but I have not looked into it closely.
What methods have you seen used to communicate with SharedPoint Portal?  Most of the methods available in other languages will be available in LabVIEW as well.
Justin Parker
Product Support Engineer
Message 2 of 12
(10,047 Views)
This is an old post although I'm facing the same challenge. Did anyone made any progress on this topic?
Thanks.
Message 3 of 12
(9,675 Views)
Some things in the original question don't make sense.  I don't know what they mean by "sharepoint column".
I tell you things that I have done.  I have used LabVIEW to put data into sharepoint directories.  The secret was finding out the explorer path to the sharepoint locations rather than the browser path.  I don't remember how I decoded the secret.
But for my situation (and I'll make some uf the paths "generic"), it was  \\SharepointPortalServerName.MyCompany.org\sites\ppm\npd\projectdirectory\..\ and so on down the directory tree.  I used LabVIEW's file copy functions to copy the file from my hard drive to the network path.  That should work as long as you have rights to save into that sharepoint directory.
Message 4 of 12
(9,666 Views)
RavensFan,
actually I've saved the files the same way you did, and I don't know either how I figured it out.
When we talk about "sharepoint column" we are talking about the sharepoint metadata, please see the image below. This is not the doc metadata, the properties are inserted through sharepoint. I've searched a lot in the web and the last I found out, is that unfortunately you can only do this things in the sharepoint server.
Message 5 of 12
(9,636 Views)
Oh it can be done, but it is not pretty.  Sharepoint is just a web page.  So read in the webpage into LabVIEW as HTML source text.  Then you can parse the text looking for.  The problem is parsing HTML raw text, made by a java script function, can be quite difficult and ugly.
Message 6 of 12
(9,612 Views)
Thanks, Hooovahh!
can be done, although I'm reading something about uploading files through PowerShell, https://www.nothingbutsharepoint.com/sites/itpro/pages/using-powershell-to-upload-documents-in-share.... So I'm planing to call a PowerShell script from Labview to set the metadata, I believe it would be simpler than parsing a HTML code.
Message 7 of 12
(9,600 Views)
It has been a while since you posted this. I am trying to do the same and I don't know much about Sharepoint, HTML or JS. Could you please give me some clue in how to search data in sharepoint using Labview or TestStand and then write some values.
Thanks!!
Message 8 of 12
(8,921 Views)
Hi, johncuitiva,
We've abandoned the idea of using the metadata because apparently it would be needed to use many licenses of a SharePoint dll than I can't recall. The project took a different direction, towards a SQL server with a Web Client.
Message 9 of 12
(8,917 Views)
Hi FBro,
Thanks for your reply. I agree using sharepoint is too complicated when you can use SQLexpress for free. However, I need to implement this connection.
Jhon
Message 10 of 12
(8,906 Views)
