Microsoft-MsgBox via ActiveX
i want to call the Microsoft-Message-Box (function "MsgBox" in VB) in my LabVIEW-6-application, e.g. via ActiveX.
In the list (offer when import ActiveX-Controls) I can't find the MsgBox or any equivalent. Can anybody help me?
Thank You.
C. Dietz
Christian
Test Engineering
digades GmbH
www.digades.com
(3,288 Views)
C. Dietz;
You can use the Windows API Function Utilities (32-bit) for LabVIEW to call the Message Window Dialog Box.
Also, as you might be already aware, LabVIEW also has a Message Box located in the function palette under the Time & Dialog menu.
You can also create your own message box.
Regards;
Enrique
www.vartortech.com
(3,288 Views)
