Microsecond delay for E-series
I have been trying a number of ways to get a 5-10 us delay using an E-series card. I first simply tried to count positive edges using a 1MHz clock but it cannot obtain such a low number. Any ideas of code would be helpful...btw im a student if that helps any 🙂
(2,795 Views)
Are you trying to get a 5-10 us loop delay in a real-time loop? I tried a simple counter-timed loop (see image attachment) at time-critical priority and could not sustain a 10us loop period. The best I could do with nothing else in the loop was 80-85kHz.
I was confused by your second statement, however, and started to think you might be trying to do Simple Event Counting with one of the DAQ-STC counters. If you're trying to take a continuous high-speed period measurement, try one of the Buffered Period Measurement examples. The DAQ-STC counters can easily measure 5-10us delays continuously.
(2,795 Views)
Hi Bob:
I'm trying to learn more about your Timed Loop.vi.
Where can I find the subvi with mark "Pulse Specs"? It looks like a function or vi from "Data Acquisition" group but I can't find it.
Appreciate it if you can comment on it.
thanks,
Min
(2,795 Views)
