Method to record "Time wave form and FFT graph result data" of analog input voltage signal (It is input for 100 seconds) in the Excel form file.
Please teach the method of recording "Time wave form and FFT graph result data (Every time)"
of the analog input voltage signal (It is input for 100 seconds)
Vi in the stage is appended while I do the programming.
Message 1 of 14
(3,801 Views)
Please teach the method of recording "Time-domain wave form and FFT power spectrum graph result data (Every time)"
Message 2 of 14
(3,796 Views)
If you are looking at saving the value part ( Y and maginitue arrays) of waveform and power spectrum, here is a simple way to do it.
Just extract the values from both clusters and write to a file
Look at attached VI
Regards
Dev
Message 3 of 14
(3,792 Views)
Thank you very much
but, my labVIEW version is 6.1.
So,If you can,
please send the sample of 6.1 version ,or,  block diagram picture.
I'm college student.
Now,I use labVIEW for my reserch.
Thank you very much for your kindness.
Message 4 of 14
(3,789 Views)
since i do not have LabVIEW6.1, I am sending a pic of block diagram
Hope this helps
Any doubts, plz do get back
All the best
Dev
Message 5 of 14
(3,781 Views)
The one connected to waveform signal is 'get waveform components' function
for Power spectrum, use 'unbundle by name' function
Message 6 of 14
(3,781 Views)
Thanks a lot.     Smiley Very Happy
I could record time-domain wave signal(y) & FFTspectrum (magnitude) data for your advise.
If you can,
please teach me how to record time-domain wave signal(x) &  FFTspectrum (frequency) data.
Thank you very very much .!!!!!!!!!!!!!!
Message 7 of 14
(3,778 Views)
Well, your x axis values of a waveform are derieved using the waveform components 't0' first point and 'dt' interval between data points
Your first x axis array value will be = t0.
the next value  t1=t0 + dt
t2= t1+dt and so on
Similiarly for frequency spectrum, f0 is the start frequency of spectrum in Hz and df is the frequency resolution.
f1=f0+df, f2=f1+df etc.
Now, i suggest you find the number of elements in the magnitude/y values array using 'array size' function and
generate a series of that size using the (t0,dt) and (f0, df) of this size
Take it up and you should be able to do this part by yourself.
If not, let me know and i will paste a pic of a sample code to do this.
Regards
Dev
Message Edited by devchander on 01-19-2006 03:36 AM
Message 8 of 14
(3,765 Views)
Thank you .
But, I don't understand how to use "array size vi".
So,please send pic.
Now,I send you my vi.(Analog signal ⇒sin wave signal)
Message 9 of 14
(3,759 Views)
Message 10 of 14
(3,756 Views)
