MessageBoxA
Has anyone used MessageBoxA in User32.dll and had any luck making the
pop up modal in LabVIEW?
I want the ability to use the default Windows Icons and Sounds that
are associated with MessageBoxA for each type of pop up (error,
warning, etc.).
Thanks!
(3,584 Views)
TLE;
The manual Using External Code in LabVIEW tells you exactly how to do that. Check page 2-24.
Regards;
Enrique
www.vartortech.com
(3,584 Views)
Click here and download the vi.
(3,584 Views)
Thanks for the reply. I have already seen that and have been able to
call the message box. The problem is that I cannot get it to behave
like the message box built into LabVIEW. I want it to be modal over
the vi that calls it as well as synchronous so the user must
acknowledge it and only it before continuing.
(3,584 Views)
Download my vi and see its code...
(3,584 Views)
Thanks!
Between all of the response I found what I needed.
Tim Erickson
(3,584 Views)
