Message display on top even Labview runs in background
            Currently in my program I am displaying a message to user, when one of the task finished in my program. It wait until or pause the program until user interaction. So, I am using "Display message VI" and it is working as I expected when I run my program.
            I would like to display a message to user even, if user is working on some other area in the same PC i.e.. Browser or playing games or some thing else. My current program did not do this and it only pop-up the message on Labview block diagram or frontpanel.
How can I display the same message even if the user is doing some thing else on the same system.
(3,059 Views)
Hey, I use LabVIEW 2011 and when I run the following vi, minimize LabVIEW and browse the internet (even in fullscreen) the dialog box pops up, as you want it to.
Dialog Box
(2,969 Views)
Hi
in order to do this using Display message Vi you can do the the following right click on the vi and select open fron panel from the list, it will be convered to usual VI, from VI properties, go to windows appearaance and check the :Top level-application window" and you will get what you want.
Hope this helps
(2,947 Views)
