Merging two PXI project
We have two pxi controller with FPGA (PXI1 and PXI2) which is run in different test rig.So we build two project for this controller but both controller FPGA VI is same.
So , Can we merge two projects in single project explore?
Is there any issue in FPGA code, if i used same VI for both pxi?
Kindly help me on this and give your suggestion.
(1,379 Views)
There is nothing in principle "wrong" with merging two separate programs running on two different sets of hardware (but sharing the same FPGA code).  However, unless you are extraordinarily careful about how you develop your code, and take great precautions to keep the various codes "segretated", "mistakes will be made".
You might consider separating your code into three segments:  one segment that is common and shared by both routines, which you'd place in a "shared Library", and two separate Projects for the two PXIs (which, I presume, do either different things with different hardware, or the same things with different hardware using different top-level code).
At some point, the two Projects will "naturally" separate -- one system will require slightly different requirements (possibly related to its different hardware), or the differences in the PXI hardware will suggest "pushing" the more capable hardware to "do more".  In such cases, allowing the two different routines to "naturally diverge" will be easier with two separate Projects.
In either case, don't do anything until you put this Project (or Projects) under some form of a Version Control System (such as Subversion or Git).
(1,335 Views)
Thank you.
Okay i will follow your step.
(1,314 Views)
