Merging different arrays as one long array
Hi there, I have some problem with merging of array.
Because of the natural of my VI, I will need to merge arrays together to form a single long array.
I have designed a VI using For loop and case-switching but the current array keep over-writing the previous array. I had enable auto-indexing on the For loop but it couldnt work.
I have attached two VI for further illustration.
Trying to merge arrays togther.vi  is the program i am working on.
Desired output of program.vi  is the actual thing i would like to obtain at the output.
Thanks for all the help.
Keith Tan
(3,221 Views)
Disable auto-indexing and replace the output tunnel by a shift register.
Use the "Build Array" primitive with "Concatenate" enabled to append your data.
(3,216 Views)
Accepted by topic author Keith Tan
Hi Keith,
it's the magic of shift registers Smiley Wink
You should always note which LV version you're using!
(3,214 Views)
Hi all, thanks for the fast response. Finally, i am able to process on to the next part of my program. Thanks for the help to you two.
I do have another problem but since it is different from this thread, I have decided to open a new thread, so that other can learn too!
Here's a Kudo for you, GerdW!
Thanks!
Keith Tan
(3,169 Views)
