Menus in LabView
Hi
Is it possible to change fonts and size of fonts in menu ?
How can i do it ?
Robert
(3,072 Views)
Not in Labview 5.1.1
Ray.
Regards
Ray Farmer
(3,072 Views)
> How can i do it ?
The font being used is probably what the system is using. That is the
default. If using LV6, open the Tools/Options... dialog, or if its a
previous version, use the Edit/Preferences... dialog. The font page
will contain font settings for the Dialog, System, and Application fonts
that LV uses. Turn off the Default switch and make the System font
larger. You may need to experiment with them to see how each is used,
and also beware that making them too large will mess up some dialog
boxes in LV because they do not do too much work to adapt to large fonts.
Greg McKaskle
(3,072 Views)
That's it what i wont.Thanks.
Robert
> > How can i do it ?
> previous version, use the Edit/Preferences... dialog....
(3,072 Views)
