Menu ring controls
Hi
I need a help,I have attached my program.
My problem is from the menu ring control if i select D1 the indicator turns on,further if i select anyother options from contol the indicator corresponding to new option turns on and the previous turns off but i need both to be on. Also i like to do if i select D1 it should be disabled(or changed to different colour---so that there is no option to selcet it again until i reset it manually).
Pls attach if there is any ex prgs.
(3,833 Views)
Hi Veeru,
you change the index of your array between 0 and 1 for every element. Do you want a binary display? If yes you switch the on color of your LEDs to blue and off to black. Then you can use the attached code.
Hope it helps. Mike
Message Edited by MikeS81 on 06-20-2008 01:10 PM
(3,830 Views)
Thanks Mike
I am working on it
(3,808 Views)
If I understood the question correctly you want the menu ring to select successive drive levels and have an indicator display the cumulative drive levels. You also want to disable previously selected drive levels. Is the attached VI close to what you're looking for?
(3,798 Views)
Thanks Smercurio...
Thats what i was working for.
pls if you dont mind if you have examples or help files on Labview ,forward to me.
Thanks for your help
(3,793 Views)
These are installed with LabVIEW. For the help file select Help -> Search the LabVIEW Help menu item. For examples select the Help -> Find Examples menu item.
(3,791 Views)
One comment regarding my example: If you add/remove items from the cluster be sure to set the cluster size for the Array to Cluster function. Right-click on the function and select "Set Cluster Size".
(3,780 Views)
