Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Menu bar language in run-time module
I have been sent a run-time program from one of our companies in Germany. When run all its menu bar items and those activated by a right mouse click are in German. Can I change this? More importantly, since running this program all my other run-time programs also now display German menus! How can I get everything back to English? Is it possible to write another run-time module to switch everything back to normal? We have access to Labview 6, 7 or 8 but I don't know which version these particular run-time modules have been written in.
(3,403 Views)
I had a similar problem and after asking the LV- support they advised me to change the Country- settings in the control panel before installing. This worked, but is not very nice for customers.
Greets, Dave
Message Edited by daveTW on 06-09-2006 01:03 PM
Greets, Dave
(3,400 Views)
Hi DaveTW,
The regional settings in the control panel still appear to think the laptop is doing everything in English. All the windows menus are OK it is only the Labview ones that are now in German. Perhaps I didn't understand you reply? Are you suggesting that I will need to re-install my English run-time modules in order to convert them back to English?
(3,394 Views)
Hi
What might have happened is that you have over written your English run time engine with the German one. You could try uninstalling your runtime engine then reinstalling it.
Has it effected all the langue setting in LabVIEW or just your executables regardless on whether they where written in LabVIEW (German) or LabVIEW (English.)
Regarding running LabVIEW (German) written programs in English you can localize your applications
Localizing your LabVIEW application to different languages
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3QKCAY&l=en-US
If you can post you VI I will have a look at it here, see what it effects and see the best way to reverse it.
Tim
Tim M| Applications Engineer | National Instruments UK & Ireland
(3,373 Views)
"Localizing Your LabVIEW Application to Different Languages" is [now] at https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3QKCAY&l=en-US
(2,621 Views)
