09-20-2012 03:59 PM
LV users smarter than I,
I have developed a UI that programmatically places cluster controls neatly on a tab control page.
The same tab control page also has a few XY Graph controls.
Within each of the clusters are the following:
String Control - Contains the channel name
String Control - Contains the "units" of the channel
Numeric Control - Contains the data value of the channel
String Control - Contains the timestamp value of the channel
Menu Ring Control - Contains a list of available plots upon which data channel will be displayed.
I am using Control References to position and populate the values of the controls programmatically.
All of this works fine.
However, whenever I have my test system running, If I mouse click on one of the Menu Ring Controls (which then pops up the list of options), my data acquisition stops until I make a selection or click outside the selection box.
I realize that I haven't explained anything about my data acquisition and where it is going on, but I don't want to overwhelm this post out of the gate.
So here are the major details.
I have multiple DAQ VIs (one for each type of DAQ equipment) that are all reentrant and called via Invoke Node.
They feed a queue.
There is a queue consumer which sends the data to a TDMS file; within this queue consumer is a subVI which displays all data live and contains everything mentioned above.
So, I don't understand why my Invoke Nodes are failing to execute while I have my Menu Ring selected.
I have come to understand that LV multitasking can sometimes cause these types of issues but how in the world do I troubleshoot?
Help!
Chris
P.S. Attached is a photo of the UI for reference. This may clear up some of my rambling.
09-20-2012 05:07 PM
To clarify, are you saying that the Invoke Node doesn't execute when the menu is visible, or that a VI that is already running (launched through an Invoke Node) pauses when you click on a menu? If the former, this is a known issue due to the way LabVIEW is structured and I haven't seen a good workaround. See similar issues
http://forums.ni.com/t5/LabVIEW/droping-down-menu-pauses-program-at-open-ref/m-p/502803
http://forums.ni.com/t5/LabVIEW/Accessing-pulldown-menu-halts-VI/m-p/1109450
http://labviewwiki.org/Lessons_learned_from_plugins
http://lavag.org/topic/1386-cannot-instanciate-new-vi-when-the-root-loop-hangs/
