Memory Full : stopped at Initialize array
I am getting an error .. see attchemnet. The output from the initialize array is wired to a for loop. (via shift registar). I have read many post related to this but could not understand anything. any solution?
thanks
Nghtcwrlr
Message 1 of 27
(4,703 Views)
What is the size of the array you are initializing?
Message 2 of 27
(4,695 Views)
I gave the dimension size as 270. Should i make it as zero?
Nghtcwrlr
Message 3 of 27
(4,685 Views)
Yes but it is a 2D array, and the other dimension is that dbl wire coming down from above.  How large a number do you expect this dimension to be?
Message 4 of 27
(4,681 Views)
That is the square root of sum of sqaure of X & Y resolutions.
Nghtcwrlr
Message 5 of 27
(4,673 Views)
That's nice. What's the value?
Message 6 of 27
(4,667 Views)
it depends up on the binary image i choose.256X256
Nghtcwrlr
Message 7 of 27
(4,664 Views)
Are you using a U16 data type in your cluster?  You might find this link worth looking over, it tells you how different data types are stored in memory.
Message Edited by jmcbee on 03-18-2009 04:20 PM
Message 8 of 27
(4,660 Views)
No. Iam using  I 32. Actually i cant set the dimension to 0.The final result is empty alwayz.
Message Edited by Nghtcrwlr on 03-18-2009 05:26 PM
Nghtcwrlr
Message 9 of 27
(4,645 Views)
A Long Integer uses 4 bytes, you have two long integers per cluster and you have about 270x255 clusters, which means that you are looking at 17556750 bytes of continuous memory.  I don't see why you would have trouble storing 17.5MB of data.  Smercurio, did I do this calculation correctly?
Message 10 of 27
(4,638 Views)
