Measuring voltage with an Analog current Input (NI PCI-6238)
is there a way to measure voltage using 6238 . . . .
I have to measure the voltage across a releay . . . abt 12V and 40 ohm.... hence i cannot use any divider ciruits ....
i have to use a voltage buffer .... followed by a voltage to current converter .... is there any other simpler way to determine the voltage
(3,919 Views)
Ohms Law?
Greetings from Germany
Henrik
LV since v3.1
(3,909 Views)
Ok let me explain my problem again .....  not sure but the way the device measure surrent is by finding the voltage across it.....   hence it has a inbuilt resistor.....so my relay coil is a resistor and not a currrent source ...which would cause a voltage drop ..... is there any other way without using buffers and v to i converters
(3,893 Views)
Don't know the possible current ranges...
But if you know the internal current shunt value , one additional series resistor could do the job at the cost of a maybe low input impedance.
Otherwise a voltage buffer and the resistor should do the job. The V->I converter is the shunt and the resistor 😉
If the OP doesn't drive the current needed, add a transistor .... (or for low cost maybe a simple pull up resistor aiding the OP is sufficient... )
Why not measure the current in the coil? It's the current that makes the magnetic field 🙂 and you can extent the current range with a bypass resistor .. (with apropriate rating 😉 )
Henrik
LV since v3.1
(3,883 Views)
its written 0-20mA    . . . .  i cant measure the current directly as it is in a PCB
(3,876 Views)
and what uncertainty do you need? coarsly 1%? if you add a 2.4k (+ shunt) in series to your 40 Ohm load ?  would add 5mA additional load to the app. 860mA ....
Henrik
LV since v3.1
(3,869 Views)
OK let me try again ... btw sorry for the mistake it 400ohm
NOw the input of 6238 consists of a sense resistor(abt 100 ohm)  followed by an amplifier with some gain Ag .... I=V/R(hence you get the current by measuring voltage)  ,.... the current fed to this shall be from some current source ....   now the problem is i cant take voltage directly from the resistor as it would vary the voltage .....
(3,858 Views)
