Measuring voltage on multiple modules with different sampling speed
I need to create a software for analog and digital input measurements. In the analog measurement will be voltage, rtd and thermocouples measured. It will be done via cDAQ NI-9189 with modules NI-9207, NI-9219 and NI-9213 respectively.
Now these modules have all different maximum sampling rates. It is critical, that I achieve the best sampling rates from all the modules, mainly from the 9207 on voltage measurement. How do I set up such a task?
If I connect all the devices into one task won´t the task be slowed down to meet the slowest device sampling rate? (the thermocouples at 50 Hz)
I have only tried a simulation, which happilly exceeds the maximum sampling rate of NI-9213, so I have no idea if ti will work or not. I am currently waiting for the hardware to be shipped in, but I would like to be prepared in advance. Basic schema of the simulation attached.
Thank you
(1,195 Views)
Hi Hemach,
If this is a strict requirement then you should setup 3 different DAQmx tasks, one for each module.
(Please note upon creating of a thread the used LabVIEW environment: it seems you use LabVIEW NXG…)
(1,189 Views)
