01-23-2013 12:21 PM
Dear All.
Sorry for disturbing again,i have one problem in measuring analog I/P,i created a analog VI measurement subVI,by using this SubVI i am going to have some 6 times repeated measurement,when i run my main VI 1st 2 measurement became low and 3,4,5 will Ok then 6th will be high,when i run subVI continuously then it measuring OK for every iteration,why changes happening while running mainVI,and i need Digital multiple line output.I created by using Case structure but i didn't get correct output,1 to 3 cases its working fine but othercases it will not correct. herewith i attached by VI,please help me.
I am going to measure Voltage then converting that into resistance by using Ohm's Law.
Thanking You.
Raikar A G
01-23-2013 12:22 PM
I didn't able to attach all vi in one post,please find other two here.
01-23-2013 12:41 PM
First of all, zip up your files when posting more than 1 or 2 files.
Secondly, why are you clearing your tasks and resetting your card each loop? You should initialize your tasks once before the loop, read/write inside of the loop, and close/clear/reset once after the loop.
01-23-2013 10:39 PM
Dear Sira
I try to upload the ZIP file,but i am not able to upload it,for that reson i uploaded each VI separatly.
before with reset i did the VI,when i run VI i didn't get predicted ouput in 1-3 case,at that time i used the reset,and clear and colse also like that only,without clear and close my VI showing error that,my task in DAQ already running.
I am using Digital output lines to a 32 in 1 Multiflexer logical Inputs,I have some 30 RTD's i need to measure the resistances of the RT,i am connected a known resistance to between RTD and Power to get current,from RTD one end connected to MUX lines from MUX output connected to AI0 line in my daq.
Raikar A G
