Measuring magnet field strenght
Hello
I work for a service company and we are now starting on servicing servo motors.
But here is the problem. The AC servo motor has a permanent magnet rotor. When I disassemble the motor there is a possibility of weakening the magnetic field strength of the rotor. How can I measure the rotors field strength before and after .
I thought about connecting the servo to an other motor, then starting the other motor and measuring voltage of the servo. if the rotor lost his "magnet strength" the voltage  will be lover then  before.
Is there maybe another  more precise  way??
Regards
Boris
(3,173 Views)
Hello
Take a look at www.senis.ch
They have a lot of small 3D Hall probes
Sasa
(2,968 Views)
