Measurement & Automation explorer no detect serial
I have a PCI 4 serial port adapter and two Xantrex xtr 20-40 power supply but Measurement & Automation explorer it's not detecting any of them, I can see all port in Device Manager but not in  Measurement & Automation explorer.
I already tryed installing VISA, and NIQMx, and I have teh version 4.5 of  Measurement & Automation explorer.
Any body can help me?
Thank you
Message 1 of 11
(8,151 Views)
here is a picture
Message 2 of 11
(8,149 Views)
According to the image, NI-VISA is not installed.
Message 3 of 11
(8,145 Views)
I still can't to see the COM ports with Measurment and automation explorer, but I can see it with Device Manager.
please see picture
Message 4 of 11
(7,954 Views)
any body has an Idea?
Message 5 of 11
(7,922 Views)
Measurement & Automation Explorer gets the listing for the COM ports from the windows registry. Can you verify that your COM ports are properly showing up in the registry under HKEY_LOCAL_MACHINE»HARDWARE»DEVICEMAP»SERIALCOMM?
-Zach
Message 6 of 11
(7,903 Views)
yes it is....
see picture
Message 7 of 11
(7,887 Views)
When you installed NI-VISA, did you make sure that Configuration Support was selected as a feature to install? You can modify the installation by going to Start->Control Panel->Add/Remove Programs->National Instruments Software->NI-VISA, then select Modify. This will allow you to see what features you have installed and which ones you don't. Make sure Configuration Support has been installed.
Justin E
National Instruments R&D
Message 8 of 11
(7,851 Views)
YES !!!
Configuration support is installed
Message 9 of 11
(7,823 Views)
Based on your last post, I cannot tell whether installing configuration support fixed your problem or was already installed. Which is the case?
-Zach
Message 10 of 11
(7,790 Views)
