Measurement & Automation Explorer cannot open Imperx Cameralink Framegrabber
I am trying to view a camera connected to an Imperx VCE-CLEX01 cameralink framegrabber. When I open up MAX, the framegrabber appears under IMAQdx devices, but when I click it, I get Error 0xBFFF800B, "The session for your device could not be configured."
I have installed the Imperx software and drivers, which states it includes a labview driver. I checked the C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Data folder and there is an ICD file from Imperx located there as there should be. I can grab images just fine using the imperx software, so I am confident in ruling out a hardware issue.
I am running Labview 2011 on Windows 7 32bit
Any suggestions?
Message 1 of 18
(7,629 Views)
We havn't found any options to make the FrameGrabber included into the IMAQdx list. To use Imperx FrameLink Express framegrabber you should take LabVIEW modules from the folder "C:\Program Files\Imperx\FrameLink Express\Drivers\LabView" - this modules are just wrappers around the FrameLink Express SDK library.
Also you can find a LabVIEW samples there.
For more information please contact the Imperx Technical Support <support@imperx.com>.
Cyril Margorin
Imperx Software Team
Cyril Margorin
Message 2 of 18
(7,616 Views)
I'm working on talking to the sane framegrabber. We don't have the NI vision. For our application, we don't really need to have the preview images. All we need to do is to snap. Can this be done with ActiveX?
Joseph
Message 3 of 18
(7,482 Views)
Hello Joseph,
You will still need to acquire the images in LabVIEW whether or not they need to be viewed. And in order to do so, you will need to successfully interface your Imperx Framegrabber with LabVIEW.
As already mentioned in the previous posts, Imperx provides drivers that allow for this interface. If you do not already have access to these files, then I would suggest contacting Imperx in order to obtain them.
If you would like any additional information on how this 3rd party framegrabber will interface with LabVIEW, please refer to this KnowledgeBase article.
Huntington W
***Don't forget to give Kudos and Accepted as Solution where it is deserved***
Message 4 of 18
(7,472 Views)
I downloaded the SDK and everything is working now.
Joseph
Message 5 of 18
(7,464 Views)
Joseph.
What do you mean saying 'we don't need to have the preview images. All we need to do is snap.'? What is a 'snap' in your case?
Cyril Margorin
Message 6 of 18
(7,454 Views)
Nice to hear it. In case of any problems with Imperx Framegrabber don't hesitate to contact the Imperx Support Team (support@imperx.com)
Cyril Margorin
Message 7 of 18
(7,449 Views)
Hi, I'm facing the same problem. I have the ImperX drivers in the ImperX folder.
How do I interface them with LabView? Do I copy the files into a specific folder in LabView?
Message 8 of 18
(7,388 Views)
Hello Low,
Yes, the ImperX drivers along with any other third party instruments drivers need to be installed in to the the instr.lib directory for your particular LabVIEW version. Here is an article that describes how to locate this file and how to install them.
Huntington W
Message 9 of 18
(7,374 Views)
Hi Huntington, thanks for the tip.
I have copied the ImperX LabView drivers from "C:\Program Files\Imperx\Framelink Express\Drivers" into "C:\Program Files (x86)\National Instruments\LabVIEW 2010\instr.lib", and renemed the folder to "ImperX", and when I tried to run Imperx's Framelink Express Snap Sample.vi, it asks for the VCECLB.dll which i pointed to the one in "C:\Program Files\Imperx\Framelink Express\Application\x64\VCECLB.dll".
However after the example loads, there was a pop up reporting 13 warnings:
- Dependency loaded from new parts (13 warnings affecting 13 callers)
What does this mean?
Message 10 of 18
(7,343 Views)
