Measurement Units Programmatically
I have a situation where the user will be required to manually enter the measurement units. I would like to programmatically extract all the possible LabVIEW measurement units and present those in a list or a dropdown. I don�t believe there is a way to do this but I would like to solicit any comments. Also, one of the units required is percent relative humidity, and this is not available as a LabVIEW unit.
Allen Weekley
(2,859 Views)
You cannot set the units programatically, but I think that I have a good programatic workaround for LabVIEW 6.1. ( I needed the event structure). This method allows you to have your own custom units.
(2,859 Views)
I tried to make the code pretty in the last minute and introduced an error. Here is the correction
(2,859 Views)
