Measure waveform overshoot
Hi all,
Is there a LabVIEW function that will measure the overshoot of a waveform? I know oscilloscopes can do this, but I need to do it in software.
thanks,
Stephen
(3,480 Views)
Hi Stephen,
i guess the "Waveform Scalar Limit Comparison.vi" should help you.
Mike
(3,462 Views)
Search the examples for overshoot. There is an example under the waveform measurements pallete for pulse and transition measurements. What type of data are you using??
(3,453 Views)
