Measure a DC voltage
Hi All,
a simple one,
I am using a USB6216 DAQ to measure a 3V dc signal. I am inputting the signal to a analog input.
Attached it the signal being read from the DAQ. Becasue of this the signal could be anywhere between 0-3 volts, which is casuing incorrect results.
How would i go about properly reading this voltage ?
Richard.
Message 1 of 8
(4,608 Views)
Hi Richard,
usually you follow the manual as it explains how to measure input signals…
How does your wiring look like? How does the signal source look like?
Message 2 of 8
(4,602 Views)
Hi lvrichard,
     Can you clarify a few things?
  • Your signal is not a DC signal but rather a more or less square wave, is this expected look?
  • Were you expecting a more or less constant level (in your case approx. 2,9 V)?
  • If the square look is expected, what value are you trying to measure, the high level (approx. 2.9 V on your screenshot)?
Message 3 of 8
(4,585 Views)
The input (confirmed with an oscilloscope) is a constant 2.9volts and not a square wave. I feel the square wave is a result of the sampling rate for some reason.
Message 4 of 8
(4,569 Views)
Pure guessing...
Your disturbing pattern is exactly at 50 Hz and I can see your DAQ step is configured in differential mode, so I would suspect you are having serious (main power) common mode issues that may overload your DAQ device. Have you connected your ground correctly? Have you tried single-ended mode and if so... does that fix your issue?
Message 5 of 8
(4,560 Views)
Hmm.  You appear to have a signal that "goes to ground" at very close to 50 Hz.  Are you, perhaps, at a location that has 50Hz A/C power?  Do you know about how to wire a DAQ device for analog voltage, including proper grounding?
While you show no code nor wiring diagram, the nature of the signal you show suggests a "wiring" issue as my "best guess".
Message 6 of 8
(4,556 Views)
Hi Bob,
I am using a differntial set up. Do I still need to connect the negative terminal to AIGND ?
This seems to solve the issue ?
Message 7 of 8
(4,549 Views)
Even differential signals need a ground reference.  So you need to make sure everybody is using the same ground.  I will just defer to a white paper from here: Field Wiring and Noise Considerations for Analog Signals
Message 8 of 8
(4,539 Views)
