May I do mutiplying of complex arrays directly as ...
May I do complex array mutiplying directly as I do mutiplying of simple numbers?
(2,626 Views)
Yes. In LabVIEW, complex numbers are a scalar number datatype and you multiply them with the multiplier node.
The multiplier node also accepts two arrays on its inputs. Multiplication is is done element by element. The size of the output array is that of the shorter input size.
LabVIEW, C'est LabVIEW
(2,626 Views)
(2,626 Views)
