Maximize Graph on Screen to full screen
I am looking to simply take a waveform graph and when I click a button next to it, I want to maximize it to full screen size.  Whn I mess with teh bounds properties, the buttons at teh bottom of the graph dont grow accordingly and it appears messed up. Any recommednations on how to proceed with this?
(4,009 Views)
Here is a crude way; you may have to play with it if you don't want all of the controsl to resize.
(3,998 Views)
Accepted by topic author id
Hope this helps you. And for controls and indicators you can adjust the width and height using property nodes accordingly.
(3,994 Views)
I think the question was getting the graph the same size as the physical screen - not the vi window -
So the problem is not solved ....
(3,730 Views)
Since the original poster of the question did in fact mark the thread as solved, we can safely say that your assumption is incorrect.
(3,726 Views)
