MaxSTREAM transmiter receiver
Hi
Does any one aver used Maxstream device named X24-009NSC  and XStream-PKG,
as a matter of fact, i m using the X24-009NSC from a compact RIO to transmit wireless data to XStream-PKG. The user manual explain the configuration in HYPER terminal as though, i want to programm it with LabVIEW.
the compact RIO will be embed in an UAV (unmaned Air vehicle) with the transmitter X24-009NSC and the receiver XStream-PKG will be connected to a PC.
I fisrt try to use both device, but i don't have any path to test them. All your suggestion will be welcome
thanks
04-01-2008 04:22 AM
(3,139 Views)
If you need help with the use of the cRIO, don't hesitate, for the other stuff I just can't help you, I only wish someone did a similar project...
Regards
Richard Keromen
(3,110 Views)
Hi Richard,
is there any VI that can be use to send data from Crio to X24-009NSC of MaxSTREAM?
(3,105 Views)
For this kind of stuff you should directly ask MaxSTREAM.
Regards
Richard Keromen
(3,103 Views)
