Max database exited abnormally
I got an Max database error message. "The MAX database exited abnormally. Visit ni.com/info and enter the infor code MAXTerminatedServiceERror if the problem persists."
I went to ni.com
url: http://digital.ni.com/public.nsf/allkb/F24AA9FB6A3A0E9D86257539006141BE?OpenDocument&metc=MAXTermina...
, I followed step by step to solve problems. But it still does not work. When i boot system. It displays the same message. What do i do to solve this problems.
Message 1 of 10
(12,526 Views)
Hello!
Thank you for posting to the NI Forums!
What version of MAX do you have? I would recommend trying the MAX Database Corruption procedure to see if that fixes the problem. If that still is not succesful, I would recommend repairing one of the drivers that installs MAX such as VISA or DAQmx.
Have a great day!
Margaret Barrett
Digital Multimeters and LCR Meters
Message 2 of 10
(12,504 Views)
nerdy,
After you start the service as described, do you still see the same error in MAX? If so, could you refresh the services list to make sure that the service is really started. I'm worried that something on your machine might prevent the services being started.
Song Du
Systems Software
National Instruments R&D
Message 3 of 10
(12,500 Views)
Is this problem being resolved? I have the same problem after installing 2010 version.
I did start the follow the link
 and the procedures, but the error still pops up. Can anyone help?
Message 4 of 10
(12,182 Views)
Hi smoothengine00,
Did you try going through the document that Margaret mentioned to clear Database corruption?  Also, did you restart both the NI Configuration Manager and the NI Device Loader services?
Jared S.
Applications Engineering
Message 5 of 10
(12,151 Views)
I did delete the database. After that the program runs fine and no more error message.
Message 6 of 10
(12,142 Views)
How come if MAX Database Corruptions are so 'rare' that you guys have your own tool to complete the process?  Smiley Very Happy
I had the same issue, as the 'NI Configuration Manager' process would not start and everytime I clicked on the devices icon it said the Database was exited abnormally.
I ran the MAX Database Corruption executable for LV2010 and it appears to be working now.
Thank you!!
PH
Message 7 of 10
(11,691 Views)
Thank you!
Same problem and solved!
+++ In God we believe, in Trance we Trust +++
[Hungary]
Message 8 of 10
(11,484 Views)
 This fixed it for me!  Thank you.
Message 9 of 10
(7,542 Views)
Just to be clear.
MAX database is also known as "XML hell"  It is really easy for people to fat finger a file that needs to be in a protected area.   Older versions of windows didn't require advanced privalages where those files hang out.
"Should be" isn't "Is" -Jay
Message 10 of 10
(7,539 Views)
