Max & Min function coerces Min output to non-typedef
I have noticed a minor issue that I think is a bug. It is illustrated below in the snippet:
When using the function in "Compare Elements" mode, the Min output is changed to a non-typedef. When in Compare Aggregates mode, it remains a typedef.  I can't think of any reason this would be intentional.  It is only a minor issue since the coercion would not be a big performance loss.  The output values are correct - which is the important thing!
I am using LabVIEW 2011 SP1
Message 1 of 8
(3,325 Views)
Is this actually a snippet?  Or just a screenshot?
I tried to drag it to a block diagram and it just wouldn't drop there.
Message 2 of 8
(3,306 Views)
It is meant to be a snippet. I created it using the "Create Snippet" menu option. I think now with IE you have to drag it to your desktop first and then onto the block diagram - did you try this?  It works for me.
Message 3 of 8
(3,298 Views)
A snippet won't have the Type Defs anyways...
Message 4 of 8
(3,292 Views)
Okay.  That does sort of help.
I know what the deal is.  I'm on a PC with Win7 newly installed.  When I drag the snippet to the desktop, it gives me Windows security dialog asking if I want to allow the file to be copied.  I say yes and it copies.  When I drag the snippet directly to the block diagram, it doesn't ask me anything.  Just gives a red X.
So it is tight security that I never had to deal with under WinXP.  That or I managed to free it up and don't remember how.  I don't know if it is because it is Win7, or if it is because of IE8 being on a freshly installed PC.  Now I'll go hunt down how to free up the security.
I found it.  And it seemed vaguely familiar, so I may have used it in the past.  I add to uncheck Enable Protected Mode in the IE8 options menu.  I also found another setting
I used the registry tip in this website.  http://superuser.com/questions/52735/drag-and-drop-images-from-a-webpage-into-a-local-folder
I also found this site that was interesting, but I didn't try to use this tip.  http://answers.microsoft.com/en-us/ie/forum/ie8-windows_other/dragging-dropping-pictures-text-no-mor... to see if it works or if it works better.
Message 5 of 8
(3,289 Views)
Ah true. Ok attached is a zip of the three files.  It can be any typedef.
Message 6 of 8
(3,277 Views)
Now that the snippets issues are sorted - does anyone have input on this issue?  Can you reproduce it?  Is it a bug?
Message 7 of 8
(3,229 Views)
I see the same issue.
In addition: If the y (lower) input is a typedef'd control instead of a constant the min output will be a typedef'd indicator. Right-click > Create > Indicator still creates a non-typedef'd indicator but shows a coercion dot.
This definitely doesn't look like expected behavior.
Message 8 of 8
(3,215 Views)
