Max. No. of shift registers on while loop?
Is there a maximum no. for the shift register to be used on the WHile loop. My application has around 10 file refnums which has to passed
plus ten other variable values to be passed to the shift registers, So around 17 -20 shift registers in one  while loop. Does it give any problem?(Labviw application crashing..etc.)
Thank you.
(2,697 Views)
Hi hema,
there is no problem. Another solution for you is, to bundle your data into a cluster.
Mike
(2,694 Views)
When I have multiple refnums to track I usually put them in an array through the shift register...
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(2,689 Views)
