Matrix as input and output
Hey
I have a program with a matrix as output. I set the matrix and run the program. The program also saves the matrix settings to a file.
What I want is to see the last matrix state on the matrix when I start the program/labview. Only way I have seen so far is to make 2 matrix, 1 as output, and one for input.
But I want it to be one matrix, wich means it must be both input and output. Which seems imposible. Is there anyway I can do this or make it looks like one and same matrix all the time?
Jonas
(2,822 Views)
Sorry the matrix is a input to the program.
And i want to see the last setting off the matrix each time I start labview
(2,813 Views)
Hi Jonas,
I'm not sure I really got your point but it sounds like a "make current value default" on your matrix control would do the job. If at the end of your VI's execution you perform a make current valur default, you will get this value the next time you start the VI, is that what you need ?
If yes, LV 8 as this feature built in, and for previous versions there are some tricks that you will find following this link 😉
Hope this helps you Jonas.
Epictetus
Antoine Chalons
(2,813 Views)
Thanks for reply.
I solved the problem by creating a property node. The program writes to file so while it runs it reads from file - Deletes file - Writes a new file, of the setup. Organised in sequens struckture.
Since the "make curren value default" function in 7.1 only made the current, and not the last default. I had to use file as memory for it.
(2,796 Views)
