Matrix Adjoint
I can only find Matrix inverse. Is there an adjoint vi?
Hardy
(3,364 Views)
The Transpose Matrix Function will return the conjugate transpose if you input an array or matrix of complex numbers.
(3,360 Views)
#include<stdio.h>
#include<conio.h>
#include<process.h>
#define N 10
//Function to find power raised to -1
int powe (int i) {
int k=1;
if (i==0)
return 1;
else {
while(i>0){
k *= -1;
i--;
return k;
//Function to display matrix contents
void display (float mat[N][N], int n) {
int i, j;
for (i=0; i<n; i++) {
printf("\n\n");
for (j=0; j<n; j++) {
printf("%10.3f", mat[i][j]);
//Function to copy matrix
void copymat(float smat[N][N], float dmat[N][N], int n) {
int i, j;
dmat[i][j] = smat[i][j];
//Function to find the transpose of a matrix
void transpose(float mat[N][N], int n) {
int i, j, temp;
if (i < j) {
temp = mat[i][j];
mat[i][j] = mat[j][i];
mat[j][i] = temp;
//function to find the determinent of a matrix
int determ (float mat[N][N], int n) {
float lmat[N][N];
int i, j, k, r, c;
float det=0.0;
if (n == 1)
return(mat[0][0]);
if (n == 2)
return((mat[0][0]*mat[1][1])-(mat[0][1]*mat[1][0]));
else {
for(i=0; i<n; i++) {
r=0;
for(j=1; j<n; j++) {
c=0;
for(k=0; k<n; k++) {
if (i==k)
continue;
else {
lmat[r][c] = mat[j][k];
c++;
r++;
det+=powe(i)*(mat[0][i]*determ(lmat, n-1));
return(det);
// function to obtain the cofactor matrix
void cofactor(float mat[N][N], int n) {
float cmat[N][N], lmat[N][N];
int row, col, i, j, k, r, c;
for (row=0; row<n; row++) {
for(col=0; col<n; col++) {
r=0;
for(j=0; j<n; j++) {
if (j == row)
continue;
c=0;
if (k == col)
continue;
else {
c++;
r++;
cmat[row][col] = powe(row+col+2)*determ(lmat, n-1);
copymat(cmat, mat, n);
//function to find the inverse
void inverse(float mat[N][N], int n, float det) {
int i, j;
mat[i][j] /= det;
//Main function
void main() {
float mat[N][N];
int i, j, n;
float det;
//scan the size of matix from keyboard
printf("\n Enter the Size of Matrix: ");
scanf("%d", &n);
if (n > N) { // If matrix size exceeds the size of allocated matrix
printf("\n Matrix Overflow");
getch();
exit(0);
//scan the elements of matrix from keyboard
printf("\n Enter a Matrix");
printf("\n Input Element(%d, %d): ", i+1, j+1);
scanf("%f", &mat[i][j]);
printf("\n Matix ");
display(mat, n); // display matrix
printf("\n Press any key ..."); getch();
det = determ(mat, n); // obtain determinent
cofactor(mat, n); // obtain cofactor matrix
printf("\n Cofactor Matrix");
display(mat, n);
transpose(mat, n); // transpose cofactor matrix = matix adjoint
printf("\n Adjoint Matrix");
display(mat, n);
printf("\n Determinant of Matrix is %8.2f", det);
if (det == 0)
printf("\n Matix is Singular, Hence cannot have Inverse");
else {
printf("\n Matix is non Singular. \n Inverse of Matrix is: ");
inverse(mat, n, det); //divide each element of matrix adjoint
display(mat, n); // by the determinent = matrix inverse
getch();
(3,186 Views)
