Matlab
Hi
I have a cRIO 9066 with 9401 and 9205 modules which I am using for the control of a robot arm. I am trying to calculate the trajectory of the arm with inverse kinematics. I am using a matlab script for the calculations and using this script within a labview mathscript node. Unfortunately the node will not recognize the 'sym' command in matlab. I need this command to create the symbolic variables needed in the solver. Is there a workaround or an alternative? Can I solve the non linear equations in Labview? I have attached the VI I created.
(2,788 Views)
Hi Sidpen,
If you are trying to solve a system of nonlinear of equations with the Mathscript Node, you can use the fsolve_zeros function.
However, that function will not work on a cRIO due to compatibility issues. I know it says on that page that it does work, but that is a known issue and that documentation is incorrect.
Alternatively, you could use the nonlinear system solver VI that is built into LabVIEW and will work on your cRIO.
Casey G.
(2,731 Views)
