Matlab script node
I'm trying to run a mathlab code from labview using matlab script node and I have a licences mathlab installed on my pc. After running the labview code it but does not run the matlab code and i dont get any error either. both softwares are 2009 version.
any help?
sbz
(3,489 Views)
This is probably not enough information to troubleshoot the problem.
Do the matlab examples from the example finder work OK?
(3,484 Views)
Hello sbz,
So your code does not run in MATLAB Script Node correctly? Could you share your code here?
Andy Chang
(3,469 Views)
Hi Andy,
Here is my code.
thx
sbz
(3,458 Views)
here it is, sorry
(3,451 Views)
