Matlab\labview interface
I have written a Neural Network function in Matlab, I want to call these Matlab codes from labview and ask them to run automatically, I wonder if there is a way to do this, any helps will be much appreciated
(3,088 Views)
The obvious way is with the Matlab Script node. You can also try the MathScript Node.
p.s. In the LabVIEW help, if you had simply typed Matlab, you would not needed to post anything here.
(3,085 Views)
